Old 06-08-2018, 03:02 PM
cycleguy55's Avatar
Originally Posted by jtubbs View Post
Need help
took out 302, installed 347 stroker from BLUE PRINT. Everything fit installed engine in car with the same steel bell housing and same T5 tranny. Motor mounts fit back perfectly...BUT the trans mount is off 3/4 to 1" and the drive shaft is 3/4 to 1" too long. All parts were same except the block--but all heads, pan, etc fir perfectly
help Jan here or email tubbsjan@gmail.com
My guess is the motor mounts aren't symmetrical, and they were reversed or flipped when you put the new engine in - thereby moving the engine rearward the 3/4-1" you're seeing.
Brian
