Yes it should blow it out. If you have an inspection mirror you may see a carbon spot on the lower side of the header flange at the leak point. Covering the mirror face with soapy water, 409, etc.. and placing it near the suspected leak area will blow the mirror clean when in the hot exhaust path.
