Old 06-20-2018, 04:26 PM
Apex_speed's Avatar
Apex_speed Apex_speed is offline
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Originally Posted by cobrarkc View Post
You might need to run a ground wire from the engine to the battery and make sure it is the same gauge as the positive lead. The newer electronic components especially fuel injection units need this to operate correctly, a ground to the frame is not sufficient. What will happen is they will look for ground through all the other wires, this could potentially burn out other components in the vehicle. If this is not the problem try an MSD Dyna Force starter.
This had crossed my mind but as I updated above, it was the battery. It was starting great all afternoon yesterday as we set the timing.
