I like how you converted the jack lift brackets to tow hooks. Did you make them?
Originally Posted by Morris
Here's how we did KMP259's Radiiator....
First we put Adhesive Silicone Rubber around the face of the Radiator.
Then we sealed the sides of the radiator
Then we sealed the top of the radiator
Now we fit the tight seal of the radiator into the vehicle so that no air can get past it for any reason
Now you can see how we installed the SS Wire in front of the radiator to protect it from rocks .... Also the oil cooler is exposed ...but it is much stronger then a radiator and easier to change.... if neccessary.
Packing the air in the radiator so it doesn't leak is very important ...also with the opening in the front of the car.... the air will slow down when it hits the radiator because the radiator hole is much bigger .... this is important as if you can get the air to slow down... then it cools much better....
Morris
