I had the single bar in mine that went all the way across and it was a 3 1/2 inch diameter.
Originally Posted by RockBit
If you are talking about a single wide loop covering both driver and passenger with no third leg brace, the ones I see are quite a bit larger than 1.5 inch diameter tubing.
If you are talking about the more conventional cobra hoop, one for driver and a second one for passenger, those are commonly 1.5 inch. Some cobra makes use larger tubing even for these.
