Old 07-03-2018, 12:49 PM
Andheeezonit's Avatar
Andheeezonit Andheeezonit is offline
Cobra Make, Engine: Superformance. 427 Windsor.
My set screw would not stay tight on the column. I drilled and tapped for a larger diameter set screw. Has not moved since.If my memory serves, there was a small piece of metal between the set screw and the column. I removed this and turned the screw directly against the column.
