Thanks guys.
I've already made the pins so will try that first.
Once set I will use retainer to hold them into the block. I tap the pins M6 thru so I can insert a cap screw or bolt to rotate them. This avoids need for a screwdriver slot.
Also if you ever need to remove, you can insert a threaded rod and make a sliding hammer to extract.
