Old 07-10-2018, 07:21 PM
Moriarty Moriarty is offline
Cobra Make, Engine: ERA 427sc
I just bought a 20819 to replace an existing 20552 which is starting to crack. The new hose is quite a bit wider and the end that connects to the radiator isn't long enough to clear the support bars. Is there a better part to use these days?
Edit: Actually it fits just fine if you bend it around the corner with the spring inside to keep it from collapsing. Hopefully being up against the frame is okay and doesn't rub too much due to vibrations.
