Originally Posted by Steve Gallegos
can you start the engine to drain all the fluid out after you have emptied the radiator?
No sir. In an FE, if you want to drain the block, the 2 block plugs must be removed. There's quite a bit of coolant in the engine. When a block plug is removed, it makes a heck of a mess. I installed one of these in each side of the block, and one in the bottom of my radiator.
