Old 07-24-2018, 07:54 PM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
A side oiler will have a pipe plug in the front of the block. It is above the oil pan and outside the timing cover on the driver side. This plug covers the hole where the oil galley along the side of the block was drilled. If you have this plug, it is a side oiler. If you don’t, it is either a center oiler or top oiler.
Chris
