Thread: Hi.
  #153 (permalink)
Old 07-25-2018, 09:14 PM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
Originally Posted by MOTORHEAD View Post
Corrosion in internal brake units is Time related, not milage. Most brake fluid is hydroscopic , it absorbs water from ambient air moisture. I think when you found this car it had been sitting for quite a while ??
Did you change the fluid ? Even If you did, that doesn't negate any existing corrosion.
Well, you may be right on. I don't know how much it sat but with the mileage showing it had to sit a lot.
