Originally Posted by ront49
I recently changed the brake pressure switch on my BDR. It was located at the bottom end of the master cylinder so some brake fluid drippled put when I removed the switch. That fluid was not purple so I added some Modul 600. What will happen "IF" I added a small amount of Dot 4 to Dot 5?
That would be a bad day. They are totally incompatible.
