Thread: Turn signal
Old 07-31-2018, 04:43 AM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Ronnie, good info. I had an Audi back in the 80's that had that problem. It would work loose and the electrical would do weird things - (lights intermittent, engine stall, etc).
Disconnect the battery and pull the connector loose look at the pins and see if there is any corrosion. Clean any of the pins that have any corrosion or black soot on them. There is an electrical grease you can buy at the auto store to help keep the pins from corroding. It is usually a white color.
Good luck!
