Engine mounts: Robert Pond alloy block
Hi guys,
Would anybody like to share the mounts they are using with the above block?
As you may know it has 4 x 7/16 tapped holes each side. I bought the flat rectangular 2241 & 2240 3 hole mounts but they don’t fit. Plus they are stepped and the machining is flat.
I know from one respondent that a custom longitudinal bush type arrangement is available, but not sure how that gonna work when I have lift under the bellhousing to slide the TKO in.
Im sure this is a well trodden path would be more than grateful for some real life pix and recommendations.
