What size are the wires feeding the headlights? Typically older cars (and Cobra replicas) were wired with 18-16 ga wire. They aren't large enough for Halogen bulbs, which draw more current . My kirkham ,with it's old time wiring has the same problem with it's sealed beams, as did my '68 and '86 Porsche's when I switched them to H-4's. You need to run bigger wires from relays, and feed the relay's direct to battery through fuse or ckt breaker to maintain 14vdc at the bulb.
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
