Old 08-05-2018, 11:26 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Check ground esp on fuel pump. If you have a fuel cutoff switch make sure it is ok. My Lucas switch depends developed a flat spot that tripped on bumps and killed the car on the freeway. I jammed a toothpick to keep it away from the trouble spot
Tony
CSX4005LA
