  #31 (permalink)
Old 08-07-2018, 10:05 AM
C5GTO's Avatar
C5GTO C5GTO is offline
Originally Posted by Luce View Post
Since this is inside the cabin of the car I would not rely on any fitting other that hard metal pipe. This means external fuel pump. It adds complexity and requires space, but a surge tank and jockey pump would be a nice addition. Fuel starvation with an EFI pump is a real problem. You lose fuel pressure and pump prime and the engine is dead until prime and pressure are regained, then you'll likely have a hiccup when the bubble makes it to the injectors.
Thanks for the reply and sorry I gave a misleading description on the tank location. It is not actually inside the cabin. It does run between the seats but the car has a "high backbone" aluminum chassis that covers the fuel tank. So there's 1/4" aluminum sheet between the fuel tank and the cabin. There is no exposure between the tank and cabin.
I'm very familiar with EFI, fuel sloshing and then fuel starvation. I had that issue in my Cobra for a long time before finally finding a solution for it. This is why I'd like to find a in-tank pump solution for the Miura.
Does the additional information change your answer?
Thanks,
Joel Heinke (early 90's CRL Cobra)
