Old 08-10-2018, 09:59 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
The original style Weber intake manifolds had no provisions for regulating water temperature as the part was intended use was for all out racing. That being said the dual outlets created a slight restriction in the size of the two manifold outlets back to the radiator.
There are aftermarket companies that offer inline thermostats that can be adapted for use with this type of manifold, some are less obvious than others visually.
