Unfinished Classic Roadster Kit:
I am the original purchaser, I do have the (CPO) Certificate of Origin with my name on it and it has not been registered or licensed. This is a series one kit. Original Classic Roadster Kit
I have what I believe to be about a 99% complete kit parts wise. PARTS LISTED ARE NEW.
Ford Motor Sport 351W (new) rated at 385 HP includes Holley Projection and Ford Motor Sport Ignition
Tremeck TR3550 with hydraulic throw out bearing
McCleod Steel bell housing
Ford Motor Sport Clutch and Pressure Plate
Howe Custom aluminum Radiator with Black Magic Electric Fan
Aluminum surge and overflow tanks
Stainless hoses
Aluminum
oil cooler with hoses fittings and
oil filter adapter
Complete rolling Chassis:
Heidts Polished upper and lower control arms
HAL adjustable Coil Over front shocks
Flaming River rack and pinion
Wilwood Master Cylinders ( Clutch, Front brake, Rear brake)
Wildwood adjustable peddle set (brake bias and height)
Wilwood front and rear disk brakes (rotors, calipers and front hubs)
Rear brakes include parking brake calipers, parking brake handle, cables and hardware
Classic Roadster adjustable rear suspension
Ford Motor Sport 8.8 rear end with 3.55 gearing
Classic Roadster Headers (ceramic coated)
Classic Roadster side pipes with upgraded mufflers
(Please note pipes are raw. They are not chromed or coated.)
Classic Roadster Roll Bar (Chromed)
Classic Roadster Fuel Tank ( Powder Coated) with sender. Includes the Lemans Style gas cap and cap to tank filler neck.
Complete wiring harness
All Lights:
Headlights, Tail lights, front and rear turn signals, back up, courtesy and trunk light.
Flaming River Custom Stainless Tilt column with wood wheel and hardware
Complete Body Including:
Doors & latches
Trunk Lid
Hood
All hinges; Hood, Trunk, Door
Complete Dash with gauges,switches , glove box and glove box door, dash wiring, heater/ defroster controls (yes I have the heater too)
Heater is complete with blower motor and housing.
Side mirrors, Emblems, Louvers, Antenna, Front & Rear Bumpers (Polished Stainless) with aluminum stand offs, Horns, Sun Visors, Wind Wings
Classic Roadster bucket seat with headrests (Black)
Classic Roadster door panels and pulls (Black)
Wind Shield with side mounting bars. (note chrome is starting to lift on the windshield frame) will need to be re-chromed.
I have many extra parts,weather stripping and hardware, Classic Roadster pedal set and hardware for cable clutch setup.
I have many picture that I can forward.
$20K-No Trades
There is easily $30K here.
