Old 08-30-2018, 11:05 AM
cobra 53's Avatar
cobra 53 cobra 53 is offline
Cobra Make, Engine: NAF 289 Blue/White strips
Default Master cylinder size
Hello from Spain
Since a longer time I have a NAF 289 Cobra Replica. I have already made lots of repairs and works on it, also with changes of front and rear breaks, also rebuild the Tilton master cylinders.
My queries is:
The breaks are a bit soft and I do not have a good feeling about the breaking point, i.e. a bad feeling when I start to break.
The clutch needs a lot of pedal pressure and is very hard to push. It works regarding slipping and chattering but still it is hard to press the pedal.
Input:
Engine SBF 289 / 1966,
Gearbox T5 WC
Pedals from Tilton
Master cylinder FB, RB, CL are from Tilton
Clutch: Centerforce Diaphragm 10.5", Hydr. Throw out release bearing, , MC Tilton 3/4 series 74, Tilton Pedal 5.5:1 Ratio
Front breaks: Calipers Forged Superlite Wilwood 120.11134 Piston 1.75"/ 4.80, Rotors 12.19" / 0.81", MC Tilton 3/4 series 74, Tilton Pedal 5.5:1 Ratio (balance bar)
Rear breaks: GM Metric emergency break calipers Speedway 91031046, Piston 2.5"? 2.02"?, Rotors 11.75" / 0.81", MC Tilton 3/4 series 74, Tilton Pedal 5.5:1 Ratio (balance bar)
I am looking for a solution, probably the "MC measures" are wrong size?
I hope you can help, will be highly appreciated. Thank you very much in advance and best regards from sunny Spain
Rico, NAF 289
