Old 06-02-2002, 03:11 PM
Slide Slide is offline
Hi Tommy, do the simple thing first and pull the distributor and look at the gear. My guess is that the oil pump seized and you sheared the the dist. gear roll pin. Put socket on the oil pump drive shaft and see if it turns with finger pressure. Good luck.
Clyde Blackman
