Old 09-04-2018, 10:49 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Start by checking the coil since it started suddenly.
Wires don't go that bad that fast in most cases.
Bad fuel is also an option, especially if you made a fill up on the way.
Check the torque on the intake in case it has worked loose. It can cause sudden vacuum leaks real fast.
