Old 09-04-2018, 05:47 PM
snapier's Avatar
snapier snapier is offline
Cobra Make, Engine: Superformance ford v8
I had s similar problem when I had a 69 Z/28 Camaro. Turned out to be a faulty coil. Would run fine for a little while but once the coil heated up the engine would shutdown. I could start it up again and about the same time frame the engine would shutoff. This would happen over and over until I replaced the coil. A funny thing happen after I replaced the coil the very next day a friend had the same problem on his car which turned out to be a faulty coil also...
