I also have a B&B with a hydraulic actuated clutch setup using a Wilwood slave cylinder. It is a great setup that has been trouble free. One thing to be a aware of is to make sure that your slave cylinder is in correct allignment with minimal to no side load. If the slave cylinder experiences any significant amount of side load the internal seals will fail and you will be rebuilding or replacing the unit. If you convert from your current cable setup to hydraulic you will never regret making the change.
