Hi classical glass. When I did mine, if I remember correctly, I used an end mill (5/8") to mill out the swage on the "L" shaped saddle. The screw shaft top is square in shape.
No way that I know of to re-swage the correct "saddle" shaped top back onto the shaft, so I had it welded and weld filled the round hole in the "saddle" and ground it to a smooth finish. Invisible after painting.
Greg
