Started the cobra today. Took a few minutes for gas to get to the Weber’s. Had two small gas leaks. One on the intake manifold and the other with the fuel line under the car. Fixed.
Car ran rough. After it cooled down discovered all 4 plugs on the driver side very loose. Likely from being removed by the header fabricator. All tight, plug wiring verified. Still need to set timing. Saturday.
Oil pressure solid at 50psi
Engine continued to run after turning key off. Will cal wiring harness manufacturer tomorrow and discuss problem.
Friend coming over Saturday to help set timing and synch carbs
Not too shabby for the initial start.
