09-17-2018, 01:03 PM
UK
Cobra Make, Engine: AC Cars Limited, 302 EFI
Originally Posted by RockBit
Mike - it is important that the PCV valve match the engine, which is hard to do on a custom nuild like yours. I fitted and adjustable PCV valve to mine made by ME Wagner. With this piece you can tune it to your engine. It comes with detailed instructions also.
Most use an oil catch can with this valve. I bought the small one from Moroso and made a bracket to attach it to the rear of my intake manifold. The plumbing is simple. The valve goes in one valve cover, hose from valve to catch can, and a second hose from catch can to the rear port on the base of your carb.
If you search ME Wagner on this forum you will see some threads about it. Google will get you to the vendor site where they have technical information.
One important thing is that your valve cover needs to be baffled. Most are.
Thanks Chris and rest of you guys. Looks like ME Wagner seemingly has the most likely solution and will get onto their website now.
