Thread: Valve seals
Old 09-23-2018, 11:00 AM
classical glass classical glass is offline
Default Valve stem seals
I really don't want to pull the heads I would like to install them on the car. I purchased a valve spring compression tool that will slide over the rocker shaft. I have installed seals on GM motors before so I know the basics. My main question is what is the best way to index the engine so both valves are closed. I do have a air pressure spark plug adapter tool to keep the valves closed when the valve springs are removed.
Thank
