For even tire wear on my BDR, I run 23 psi front, 16 psi rear. These numbers were obtained using an infrared temperature detector to obtain temp readings across the tread width, corrected for camber settings. As opposed to my usual method, which is pulling them directly outta my a$$.
Bill
"If your work speaks for itself, don't interrupt"
