Old 09-28-2018, 01:37 PM
jhv48 jhv48 is offline
I’ve noticed that my right front wheel locks first on a hard stop if there is no passenger in the car. Definitely corner weights are off at that time.
However, both fronts lock simultaneously if I have a passenger that weighs around the same as I do.
Try it with a passenger and see what happens. If that cures it, and if you do most of your driving solo, then you should corner weight the car for proper balance. I drive 99% of the time with a passenger, so mine is setup for that. If I drive solo, I have to remember that the right front will lock first if I have a panic stop.
Jim
