Originally Posted by bobcowan
This car is a street car only. Just for fun. But, being a racer, I really want good brakes. These don't seem to work as well as my truck. For power brakes, they really are disappointing.
When I get time I'm going to check the vacuum line. I'm wondering if there just isn't enough vacuum to run the brakes. Makes me wonder if I can simply add a big reservoir, or if I need a pump and reservoir.
If you're not running a reservoir you should add one. Don't forget a proper check valve(s) to hold vacuum in the reservoir.
Article here on installing a vacuum pump, including diagrams showing check valves:
https://www.powerperformancenews.com...acuum-booster/
