Originally Posted by my427cobra
Electronic regulator dressed as a 60's period correct electro-mechanical regulator:
Cover is upside down, the plug should be at the bottom of the cover with the text readable. I would guess that with the wiring in your car, you installed the cover to be "readable" from the normal hood open position but correctly it would be opposite!
And what you suggest is what I did in the 80's and 90's as a Ford Restoration Parts license holder! We took electronic units that we special ordered with the "tall" cover and stamped them to the various engineering numbers used on 60's Fords.
