Originally Posted by DanEC
I have the Girling rear, in-board brakes and I've been able to bleed them from underneath with a bit of dexterity involved. I installed speed bleeders early on which makes it simpler. I just have to crack them open, stick a hose on them to a jar and then simply pump the pedal until I'm satisfied all air is gone.
I also installed the speedbleeders a few years ago when I had the access panel removed for the rear pinion seal issue I had. I am now able to bleed the brakes from underneath (with a lift) without removing the back panel. The back panel is a hassle to remove because I believe everything (seats, tunnel, carpeting, fire extinguisher )needs to be removed first. As Dan said, requires a little dexterity but very doable. Finding the perfect shaped wrench also plays a role. I think I remember bending one of my wrenches for this job.
That said, it is a snap with the access cover removed!
