Originally Posted by strictlypersonl
Maybe just a flat rubber plug that you could glue carpet to?
Any access is better than what you have to do right now for an ERA outboard braked rear with the emergency brake. To grease the front u-joint, you have to rotate the drive shaft to just the right spot, release the e-brake, and the little brass circular thing slides back and gives you just enough room to get a pistol grip lube fitting up in there. No where in the manual does it tell you that you have to release the emergency brake in order to even see the zerk. It took me a while, and mostly luck, to figure that out. If the emergency brake handle is up, you don't stand a chance and it looks absolutely impossible. I now can do it pretty quickly, but I would still prefer a little lift up carpet flap, with a rubber plug under it that you pull out, and then you can lube it from the side. I can see that for complete u-joint change out you're going to have to pull the tunnel.
