Old 10-09-2018, 02:12 PM
spdbrake spdbrake is offline
I agree Brian.
I have noticed quite a few filter manufacturers are making filters without bypass valves Fram and Wix for example. Not all applications mind you but it does give a viable option for folks who don't feel the need for them as clogged filters are more a thing of the past.
I guess in theory you could see an increased oil pressure over what the cold oil reading your used to IF the filter bypass was kicking in help in the past. Since the oil pump pressure regulator is doing all the work it was designed for.
