Thread: Low Voltage
Old 10-12-2018, 06:10 AM
strictlypersonl strictlypersonl is offline
Originally Posted by fastd View Post
follow up:
there was no dedicated ground wire directly on the alternator (was grounded through the bracket); adding the ground wire definitely helped improve the voltage but it still drops down to 12.2-12.7 for like 20% of the time at idle after it gets warm. The regulator and battery grounds seem good.
The black wire to the alternator (as all black wires in the harness) are grounds. That particular wire is grounded at the firewall near the starter solenoid. That is where I would check first. The voltage regulator is also grounded to the same connection. A lack of ground at the regulator might give your symptoms.
