Old 10-22-2018, 06:27 AM
AC Ventura's Avatar
AC Ventura AC Ventura is offline
Cobra Make, Engine: AC Cars Limited, 302 EFI
Default Ford FE remote oil filter question....please
On a typical FE Cobra we are all used to seeing the oil filter raised from the bottom of the block and relocated to the front of the motor, high up on a bracket attached to the water pump. The incoming hose from the block runs vertically upwards to the typical oil filter casting unit, then exits downwards through the cooler and finally back to the block.
My question is that when the motor is off, doesn't all the oil drain out of that first filter hose leaving a pipe full of air, that enters the crank bearings on start up instead of pressurised oil?
