Old 10-22-2018, 04:34 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Generally, all warning lamps are fed with 12v positive in parallel, the other side of each lamp is grounded by a switch, either a oil pressure switch, high engine temp switch, alternator warning lamp circuit etc.
Making them blink could be done with a 2hz "flasher unit" using a 555 timer relay circuit.
Gary
