Originally Posted by jon@harrison.ne
"Generally, all warning lamps are fed with 12v positive in parallel, the other side of each lamp is grounded by a switch, either a oil pressure switch, high engine temp switch, alternator warning lamp circuit etc."
I don't think you want to wire the alternator (charge light) to ground!
The alternator charging lamp has ignition feed on one side like all the other lamps.
The charging lamp is on with the key on engine off, because there is ground from the alternator.
Engine running, the volts is the same on either side of the lamp, and the lamp is out.
