Granted input is helpful - thanks a lot!
Yep, tolerances are very tight.........as indicated i grinded a certain portion of the handbrake assembly down -> works technically just fine since 4 years -> still I had something stuck between handbrake assembly and wheel stuck (probably a small stone) and the scratches on the inner side of then wheel are deeper than I like them to be Yep, everything is technically still fine since four years but I want do something good to my KMS 😀
So I understand Trigo are the ones I need to go for.........shall check
Thanks again to all contributors
