Oil Leak Through VC Studs
Hi all.
I have an Fe with aluminum heads and cast aluminum valve covers, with a leak on the right side. I replaced the valve cover gasket and it still leaks. Close inspection reveals the the leak is through the stud threads.
I removed the studs and wrapped them with teflon tape. Still leaks. Anyone know what I should use to seal the threads with?
Thanks in advance.
Chris
