Originally Posted by spdbrake
Thanks. The gasket is tight and dry on both sides all the way around the studs. The holes the studs are in, at least the leaking ones, are not blind holes. The
oil is coming into the bottom of the hole and going up the threads. The heads are aluminum so the studs get looser when the engine heats up.
I thought the teflon tape would do the trick, but maybe I didn’t wrap the studs enough times. Something that will seal the threads in the hole will do the trick, but I’m not sure what to use.
