Old 10-31-2018, 12:33 PM
patrickt patrickt is offline
Originally Posted by MOTORHEAD View Post
If you are using the old Ford expansion tank, where should the cold water level be?
Also, what temp thermostat are you running ?
Ted
It doesn't matter what the level is. If you overfill it then it will just spit it out and then find its own "natural" level. Mine, when cold, is about an inch above the bottom of the tank.
