Old 11-13-2018, 10:59 AM
cycleguy55's Avatar
Originally Posted by tortuga View Post
Gauge reads Zero when ignition is off, fans take it down like they should but not as far as usual, system voltage 12.4 off, ~13.8 running, all connections on ign switch good, batt connections tight, optima red top battery couple years old..
Almost like the null has moved when running? The farthest down I can get it with ALL loads idling at about 950 is about +7 amps...
Battery cranks it right up.
Anyone had similar issue?
Properly wired, with the ammeter between the alternator and all loads, an ammeter measures the total current flow - not the 'net' from the battery. See the diagram here: https://www.fwmurphy.com/uploaded/do...00-02-0207.pdf
A 7 amp reading at 12 volts is 84 watts, but of course 12 volts is really a nominal value so probably in the range of 90-100 watts. Regardless, how much power does your ignition system draw? MSD 6 series are about 1 amp/1,000 RPM, while 7 series are slightly higher. Ignition coils draw 3-7 amps.
7 amps at the ammeter at idle doesn't appear unreasonable.
Brian
