Originally Posted by tortuga
Gauge reads Zero when ignition is off, fans take it down like they should but not as far as usual, system voltage 12.4 off, ~13.8 running, all connections on ign switch good, batt connections tight, optima red top battery couple years old..
Almost like the null has moved when running? The farthest down I can get it with ALL loads idling at about 950 is about +7 amps...
Battery cranks it right up.
Anyone had similar issue?
I think everybody is reading this thread incorrectly going by Steve's opening statement.
I read it as +7 amps, (positive) not negative, at idle.
