Old 11-24-2018, 05:10 PM
spdbrake spdbrake is offline
Originally Posted by coreyc View Post
After hitting the drain plug off the road with my stock oil pan (T&L 347 stroker) I am here again looking for advice. I only had 3.5" of clearance with the stock pan so I am looking for a pan with a maximum depth of 7.5". Can anyone recommend the most reasonably priced option (model number) if there are more than one to select from? It doesn't matter to me what brand name it is as I only do a few hundred km's per year, no racing etc, I just want to get it back on the road.
Since your are after a Stock style pan at the lowest cost I'd go with a Summit Racing PN SUM-G3520B (rear sump) or PN SUM-G3534 (front sump) both are $45.00 Both are Approx 7.75" deep
https://www.summitracing.com/tx/part...view/make/ford
Gasket Fel-Pro PN SFLOS13260T https://www.summitracing.com/tx/part...view/make/ford
RTV for the Crank seal radius corners (just a small dab) Permatex Ultra Black RTV Silicone 82180https://www.summitracing.com/tx/parts/ptx-82180/overview/
