Old 11-24-2018, 06:36 PM
strictlypersonl strictlypersonl is offline
You'll need to run another wire from the voltage regulator to the warning light (after disconnecting the red jumper at the regulator). You'll need a wire from the fuel level power to the light and to a shunt resistor. I'll check on Monday whether I've got all the details worked out somewhere. I may have already done it for the older 427s.
* Looks like Pat found it for me...
