Just an update. Car is back and all repaired. Rocker shaft broke and as a result, bent push rods, crushed lifters and bent valves. So, both heads removed, machined and completely redone, new valves, lifters and roller rocker setup. While motor was out, had clutch, flywheel, rear main seal and starter replaced. Not cheap, but done right. If you don’t have end stands on your rocker shafts, get them installed quick to avoid what I went through!
1995 ERA #418
