Bernie:
I don't think you need a special cam for Webers. The camshaft should be designed around the style of engine you have or want(comp. ratio, rpm, streetability, cylinder head flow, etc.)
Maybe I don't understand your question.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
