Old 06-04-2002, 07:24 PM
pbrown's Avatar
pbrown pbrown is offline
Cobra Make, Engine: Franklin Mint 427S/C replica
Rick is right. Get a good road race pan like the Canton 15-680. This is a high capacity pan with a low profile so it won't hurt the ground clearance. It has internal baffles and trap doors to keep oil around the pickup. You might also look into a Canton Accusump oil accumulator.
Your on the right track for getting it back in order. Be sure to remove the pump cover and check for metal bits inside.
Patrick Brown
http://www.uniquecobra.com
